after shut down will not start for 20 min
john d g
09-05-2006 18:36:44
have a JD301A (industrial 1020) gas tractor after shutdown if i try to start it again engine turns extremly slow if at all---- i move the implaments to remove hyd press from the system-so it does not appear to be that---thanks in advance for ure help-----john
buckeye al
09-06-2006 15:22:31
 Re: after shut down will not start for 20 min in reply to john d g, 09-05-2006 18:36:44
Proper ignition timing and advance mechanisims?
jdemaris
09-05-2006 19:51:05
If the hydraulic system is causing it, you're not going to get around it by simply jiggling on levers or the steering wheel. The hydraulic system is the #1 problem in regard to hot-cranking in just about all John Deeres. Cheapest and easiest fix is to install a manual pump destroker. Or - fix the internal hydraulic problem. I just fixed a JD300 Deere last week that had the cranking problem for years, but it started fine with the destroker. Finally got around to fixing the hydraulic internal leaks which included a bad hookup to an Alamo sickle-bar mower and also two problems in the three-point hitch lift that demanded oil all the time.
Gary from Muleshoe
09-05-2006 19:25:47
It is possible that your starter is not functioning properly. Have tried jumper cables from another battery to see if it turns faster? Sometimes when the engine is hot it heats up the starter and causes it to drag if the brushes are bad. Another possibility could simply be a bad battery.
