Hydrostatic Transmission is locked up!
Kuveli
09-05-2006 12:03:51
My John Deer Model F-525 Hydrostatic Transmission is locked up. It can not go back or forth. Engine runs but it does not move. I need word of wisdom about how to troubleshoot the Hydrostatic Transmission from anybody please.
Thank you in advance.
JD lover
Kuveli
scott mckelvey
09-07-2006 20:48:08
 Re: Hydrostatic Transmission is locked up! in reply to Kuveli, 09-05-2006 12:03:51
check underneath to make sure brake linkage hasn't bound up or jammed. I had one that wouldn't drive, and the parking brake was still locked even know the latch lever was released
Mike M
09-05-2006 12:09:13
Did this just happen all at once ? Maybe check the linkage for binding and see if somehow the lever you move so you can push it around got moved.
Kuveli
09-05-2006 20:36:34
 Re: Hydrostatic Transmission is locked up! in reply to Mike M, 09-05-2006 12:09:13
It all happened at once.I tried to push switch button to by pass the Hydro-drive so that I can move it still it does not work.
Thank you
Kuveli
09-05-2006 20:31:15
It all happened at once.I tried to push switch button to by pass the Hydro-drive so that I can move it still it does work.
Thank you
