46 A shifting problem
Rick in Michiga
09-05-2006 11:05:14
Just got it home - runs great. Drove it about 100 yds out in the field in 1st gear and turned around. Put tranny in neutral, high/low lever in high range, tranny back in the same gear slot (3rd?) and drove back to the garage. Attempted to put it back in low range...
Now I'm stuck with the shifter in neutral - won't go into any gear or even move up/down in the neutral slot. High/low lever moves between high low - can feel it engaging, but pulley appears to be "locked up" when the clutch lever is pushed forward.
Please help?
MDM - suggestions?
MDM
09-05-2006 19:20:18
 Re: 46 A shifting problem in reply to Rick in Michigan, 09-05-2006 11:05:14
Rick, it sounds like you have locked the transmission in 2 gears, you can unbolt the shifting quadrant and lift it strait up and you will see the shifting rails, they should be lined up to be in nuetral. Post back and let us know what you find
Rick in Michigan
09-06-2006 05:07:40
 Re: 46 A shifting problem in reply to MDM, 09-05-2006 19:20:18
I tried rocking the tractor back and forth by hand, then started it and engaged the clutch just a little while putting light side pressure on the shifter and it slipped right into reverse.
Drove it around for about an hour using different gears - everything worked fine.
Must have been the do-ma-flitchy relay was sticking... =8~)
MDM
09-06-2006 21:39:05
 Re: 46 A shifting problem in reply to Rick in Michigan, 09-06-2006 05:07:40
Rick, take a minute and look at Pat's web site....it is a very good site and very helpful!!! even though it is for the model H....many procedures apply to the A
Marvin
P Browning
09-06-2006 07:08:18
Rick -- MDM gave you some sound advice. Making a repair to the gearshift is a whole lot more pleasant if you do it while you still have a complete transmission!
Take a short stroll over at the JD-H Restoration Site. one-click on TECHNICAL ISSUES over at the left side. When the document comes up, go to REBUILDING THE GEARSHIFT to get an idea of what you are up against.
The early styled tractors were built allot alike --making use of B387R snap rings on the gear shift lever to set the fulcrum ball location (bottom) and spring tension on the fulcrum ball & socket (top). These snap rings get weak; they are made from rectangular stock, installed into a rounded groove on the lever, and the arrangement will eventually allow the snap rings to fall away over time -- the result being a rather sloppy gear shifter.
When spring tension no longer holds the gear shift lever in position, the lever can momentarily disengage from a shifter -- leaving the associated gear engaged. And when you use the lever to grasp another shifter and move its gear into positon, you now have the tractor in two gears -- it cannot budge, and to engage the clutch should kill the engine! Now -- you have to know this is not healthy for the tranny, and at miminum, you need to pull the top tranny cover and have a look. (PatB)
