48 A backfiring
Nancy Howell
09-05-2006 10:35:42
When I drive my 48 A downhill without any load, it backfires. The steeper the hill, the more it backfires. We've tweaked the carb and it helped, but it still backfires. Comments/suggestions?
Nancy Howell
09-08-2006 08:19:31
 Re: 48 A backfiring in reply to Nancy Howell, 09-05-2006 10:35:42
Rav- let me say first that I never drive a tractor fast, never. Its a good way to get hurt or wind up dead, so there's plenty of brakes for what I do. I have a great deal of respect for my tractors with their power and weight and use them and all farm machinery carefully. My "cruising" gear is 3 (lever in High position). This is a nice speed for our evening "tractor tours" around our property. Not fast, but not real slow either. I'll try using light braking to "load" enough to stop the backfiring. We can't "preach" safety enough. Thanks.
Ravgardner
09-06-2006 05:14:06
I believe your tractor is OK. It is normal for a JD going down hill to load up on unburned fuel and backfire. I would recommend you change your driving habits and not the carburetor. The carb should be set according to guidelines in the manual for fast idle and load needle settings. Then left in that position. I don't think you should set a carb for downhill operation.
Now! The engine will backfire more if it is "over-reved" going downhill. You need to slow down! I think this is why you are experiencing the backfires!! I suggest you do two things: 1) Shift to a lower gear before you get to the top of the hill. 2) Gently work the brakes to keep the engine speed slow enough to limit the backfiring. If you can't limit the speed and backfiring with the brakes, choose a lower gear the next time.
Its a fact that these brakes do not have the power we are accustomed to using with our cars and trucks. After all, there are only two brakes to slow a 5,000 pound tractor. You must use engine braking properly for the good of the tractor and more importantly your safety.
I'm sorry is this comes across as a little bit "preachy," but I've seen this before and I'm concerned about your safety. Try these procedures and get back to us with your observations.
MITCHP
09-05-2006 12:28:36
NANCY, MINE DOES THE SAME THING, DO YOU HAVE A LEAK AROUND THE MANIFOLD OR EXHAUST PIPE? I NEED TO CHANGE MY MANIFOLD SO I HOPE IT'LL CLEAR MINE UP, THE IDLE STOP SCREW ON THE CARB MIGHT HAVE SOMETHING TO DO WITH IT, TRY SCREWING IT IN SOME
