Rear cover and pto shaft removal on M?
Al Epp Waldorf
09-04-2006 18:04:29
I need to remove the rear cover and pto shaft to clean the sludge from the trans and rear. Will anything fall out of place when I pull out the shaft? Will it go back in easily? I also want to remove the top cover where the shifter is, any special procedure for this?
Mike M
09-04-2006 18:11:13
 Re: Rear cover and pto shaft removal on M? in reply to Al Epp Waldorf Md, 09-04-2006 18:04:29
The top cover will lift right off,just make sure it is in neutral first. I think that back cover will also come off pretty easy. If you have a belt pulley assy. you may need to pull it off first.
Sheridan Hoopengarner
01-22-2007 06:43:16
 Re: Rear cover and pto shaft removal on M? in reply to Mike M, 09-04-2006 18:11:13
Hello,
Do you have any info on the deletion of the belt pulley and replacing with a cover. I have a 1948 M and would like to remove the belt pulley and put the cover over it. I am not sure what needs to be removed.
Thanks
