4020 crank pulley
toby
09-04-2006 16:47:01
Fan belt broke when I took the hydraulic pump clamp loose one of the ears fell off the crank pulley. Is the drive for the hydraulic pump and the crank damper and pulley all one piece. Also can I get it off without taking the front end off?
Toby
msb
09-04-2006 19:05:55
 Re: 4020 crank pulley in reply to toby, 09-04-2006 16:47:01
The vibration damper is two parts pressed together (with a rubber damper in between) under tremendous pressure.(manufactured here in Indianapolis) If one of the ears broke completely off and you can"t get a bolt in the hole then you will have to use a pulley puller on it.Its easier if you remove the radiator to get to the job. Its also a good time to replace the front crankshaft seal while you are at it.
Glen in TX
09-04-2006 17:08:09
Check out the parts catalog and see?
