Anti- freeze or not?
MGB
09-04-2006 14:50:42
I live in Michigan, Is it best to use anti-freeze or straight water and drain for the winter? Would it keep things from rusting if anti-freeze was used?.
Thanks MGB
Greg in MO
09-08-2006 09:08:06
 Re: Anti- freeze or not? in reply to MGB, 09-04-2006 14:50:42
I would say it depends on if you expecting to do any engine work on the tractor in the near future. If so, I would stick with water, as antifreeze can be a hassle to dispose of in some places.
Once the tractor is running well and you don"t expect to have to drain it, then go with the antifreeze.
Greg
leon
09-05-2006 04:21:01
On the other hand, if the old girl has a bit of a coolant seep into the crankcase or past a gasket to a nice paint job, maybe water and draining is best. Antifreeze sure does funny things to the color of paint.
gold-l;eaf-deere
09-04-2006 18:39:37
I am for leaving antifreeze in old tractors, yesterday we drug a 37 D out of the barn, first time in 18 years, we had it running in four hours. I told the 10 year old grandson to go get some water for the radiator and much to my surprise he had already check the radiator and it was full of at least 20 year old anti freeze.
John T
09-04-2006 17:37:10
MGB, yeah I know some of the old timers drained versus using anti freeze plus if the tractor had water injection one didnt wanna run anti freese in them sooooo oo like the rest I would DEFINITELY use anti freeze n pre mix it 50/50 prior to installation. Looks to me like parts immersed in coolant are less exposed to oxygen so maybe less rust (oxidation) versus letting it sit there unprotected, but Im no metallurgist.
John T
Glen in TX
09-04-2006 17:12:02
It has also been found by many of us that you need to pre mix the water and antifreeze some to get a good stable mixture of protection in the JD thermo siphon systems.
Pappy
09-04-2006 16:40:30
Follow the great advice of Mike M.
Mike M
09-04-2006 14:59:05
A 50-50 mix of antifreeze is the way to go. Not only will it keep gaskets from drying out it should prevent rust below the water line and prevent MAJOR damage from an unexpected cold snap should you forget it has water in it.
MGB
09-05-2006 06:31:04
 Re: Anti- freeze or not? in reply to Mike M, 09-04-2006 14:59:05
OK Anti-Freeze it is.
Thanks. Mgb
