JD 50 shift forks
rbmporter
09-04-2006 11:59:11
Hello all,
When I allow my 50 to idle for awhile, sometimes the transmission will lock in 4th or 6th gear even though you are in Neutral. If you put the transmission in any gear gear, the tractor locks up totally. If I allow it to idle on a side hill, it works it way out.....worn shift forks??
thank you in advance for any advice...
Bruce
ET
09-05-2006 11:20:47
 Re: JD 50 shift forks in reply to rbmporter, 09-04-2006 11:59:11
4th and 6th are held in by a ball and spring that you can get at by unbolting the shift cover. Its under the gasket. My guess is somebody lost the spring.
55 50
09-05-2006 08:40:26
Sounds rather dangerous to me. I"d fix it before using it anymore. Major breakage could happen in the existing condition.
Kurt_JDB
09-04-2006 12:58:01
Could be that you have a broken spring that pushes the paul into the shifter shaft. I believe the 4-6 gear shifter shaft paul comes up from below, and maybe if the spring is broken, it won"t catch. This would be an easy fix, if that the case.
Kurt
