Grooves in flywheel JDA
NortexJD
09-04-2006 06:23:21
Should one groove in the flywheel be deeper than the others so that it lines up with a screw in the crankshaft spline? My replacement flywheel does not have this deeper groove. Any theories?
Glen in TX
09-04-2006 09:52:06
 Re: Grooves in flywheel JDA in reply to NortexJD, 09-04-2006 06:23:21
Styled A parts catalog shows D1080R locating screw used up to # 617574. I&T JD-4 will tell you some flywheel hubs had a rivet that aligns with a cutaway spline on shaft. On H and the A tractors after 617573 the "V" mark on flywheel will line up the "V" mark on cranshaft. Be sure the square headed dowel locator pin in flywheel aligns with the notch in slinger/spacer when pushing flywheel on and you want a minimum of .005"-.010" flywheel endplay without binding before final tightening of flywheel bolts. This site's parts section and many other vendors sell the I&T JD-4 shop manual that covers A,B,D,G,H,M & MT tractors.
