Final, on Alternator I promise
Osage
09-03-2006 16:59:57
As stated in earlier posts momentary grounding of the test hole on a non charging 10SI Alternator at first produced a slow run up in voltage to approximately 17volts, then later quit charging totally.
However, it is interesting to note that after removing the Alternator I had it tested on an analyzer at a parts store it produces a solid charge rate but the voltage is too high.
Needless to say, a new alternator has been ordered.
Osage
Osage
09-04-2006 16:45:34
 Re: Final, on Alternator I promise in reply to Osage, 09-03-2006 16:59:57
Glen:
I had an alternator refurbished once, actually (4)four times by a very good shop that did them for several companies.
Finally, after I returned it for the fourth time, I said just give me one off the shelf, which as expected solved the problem. As far as I know they are still trying to figure out why the old one tests good but doesn"t charge when its installed on the vehicle.
Osage
Glen in TX
09-04-2006 22:06:31
 Re: Final, on Alternator I promise in reply to Osage, 09-04-2006 16:45:34
They were probably too cheap to change out rotors and stators hoping to pass off old ones? New parts can be bad too and rewinds bad too with a whole batch of new parts bad sometimes and that one gremlin that will eat your sack lunch. When wiring looks burnt and insulation looks old and bad in a stator or rotor I replace them because they won"t last and will come back later if not sooner. The Delco 10SI is still one of the simplest ones to fix out there and maintain compared to older Chrysler or Motorola or any of the newer ones made now too.
Lee B
09-04-2006 00:48:04
Interesting is an understatement. That, then some and double dog confusing to boot.
In total, the symptoms for your 'bad' alternator now indicate several fishy things, like your parts store is lying to you, or you have it wired wrong, or something really odd like leaving a contactor in the 'test' hole(somehow?) or loose screws, and possibly a combination of any or all of the above. Symptoms just don't make any sense here otherwise. I have gotten parts store alternators that didn't have their external and/or internal screws/fasteners tightened properly, this could explain most if not all of your symptoms. Diodes and transistors when overloaded with current typically short out for good, but sometimes they will first short out and then open up after cooling down. In no case do they ever recover and start working again after such an event - but a loose screw makes contact whenever it wants to, or doesn't.
No need to limit yourself to 'last post' promises on a subject until a resolution is at hand. Hopefully a new alternator is just that. Only good thing about that approach is you won't have to pay a core charge this time around. But if you are not comfortable ripping into and replacing the guts of the alternator, it's the best and fastest way to the finish line. Best of luck.
Glen in TX
09-03-2006 18:52:26
Bad regulator. Enclosed so no adjustments and just replace it. You might have replaced regulator doing it yourself and still found other things bad in it too or got the rotor and stator too hot from overcharging and it wouldn't have put out as many amps then.
