2040 vs. 2640
Bill from MA
09-03-2006 12:22:38
Planning to look at a private sale 2040 with 4600 hrs and a 2640 with 5600 hours at a dealer.
Will be used to bush hog a 10 to 12 acre very hilly meadow.
Big Dean had a nice used purchase check list for M.F. Any info on Deeres?
My biggest concern would be the clutch. Should these each still have the original clutch? How long to they usually last, sans abuse? Any easy checks?
The 2040 is $2k cheaper and 500 lbs lighter so I am thinking it would be alot easier on my 1500 Suburban to move around but is the additional hp a hugh advantage ? 40 hp is the minimum for a 6' mower per the Howse website.
Thanks,
Bill
machinery-man
09-04-2006 05:21:24
 Re: 2040 vs. 2640 in reply to Bill from MA, 09-03-2006 12:22:38
Purchased a 2040 this year and can"t say enough good about it. Is the later Manhiem tractor and is very heavy, operates a 6" JD bushog MX6 and makes mince meat of the grass. I think it is 40 h.p. I traded a restored 755 for it at Clarksville, Tnn dealer. Had to do about $1000 mostly odds and ends no major. Excellent tractor, has spin out wheels, would recommend, can move in 5-10 minutes. Don"t know much about the other model except you generally can"t get tooooo much HP.
buickanddeere
09-03-2006 13:18:35
Price a 5105 with M4WD before you decide. On hills etc you will not regret 4x4 for an instant. The cheaper 5105 can have the pump turned up to the otherwise identical 5205's HP. Warrenty on a new tractor rather than taking chances on a 25 year old is appealing. Make certain the sleeves are not rotton from old coolant. And after a few hours operation. Check the trans filter and screen for fiber and steel. Non wet clutch oil if used in the trans is trouble. Some tractor owners only spend money or time on a machine when it won't run.
Bill from MA
09-03-2006 18:57:09
 Re: 2040 vs. 2640 in reply to buickanddeere, 09-03-2006 13:18:35
Great idea but the cheapest MFWD 5105 in MachineFinder is $17,500. I was thinking an older heavier utility with more hp is as good as a newer lighter MFWD.
There was 1 2WD 5105 for $10k. I might get my wife to buy into that but not to $17k.
Do you think they can be had cheaper? I can wait a year if I had to for a good deal.
Bill
buickanddeere
09-03-2006 23:10:40
 Re: 2040 vs. 2640 in reply to Bill from MA, 09-03-2006 18:57:09
Save some $$$ for a M4WD nest year then. As for HP a 5205 has plenty enough for your chores.
Bill from MA
09-04-2006 10:23:27
 Re: 2040 vs. 2640 in reply to buickanddeere, 09-03-2006 23:10:40
Deere web site lists a 5103. I'm assuming the xx05 series are the previous series. What is the series before the xx05? All the xx03's in MachineFinder were very low hours so maybe I can go alittle older?
A few years ago we rented a small Kubota and it just took way to long to cut the field, about 12 hours so I know I have to go bigger but the machine won't get alot of use so don't want to tie up big money if I can help it.
buickanddeere
09-04-2006 20:14:08
 Re: 2040 vs. 2640 in reply to Bill from MA, 09-04-2006 10:23:27
5000 three, 5000 five and 5000 twentyfive are all 2006 models . The 5000 three is a bare basic 2WD built in India tractor. The 5000 five is a basic no frills tractor that can be had with M4WD and options.US assembled. The 5000 twentyfive is a fancy bells and whistles machine. Also US assembled. All the model(s) info is on the JD web site.
