JD 4320 Making Oil?
Wayne Wright
09-03-2006 11:32:59
MY 1973 JD 4320 seems to be making oil. It was bubbling out the filler pipe today and when I checked it was twice the amout needed. I changed it a couple months ago and I know I put the correct amount in. It is also very thin which makes me think it may have fuel in it. Is that possible? If so, how could that happen? Any suggestions?
Wayne
BRUSTER
09-04-2006 06:50:27
 Re: JD 4320 Making Oil? in reply to Wayne Wright, 09-03-2006 11:32:59
EARLY 60 SERIES DETROIT ENGINES HAD THIS SAME PROBLEM, INJECTORS WERE THE PROBLEM ( STICKING, OR BAD SPRAY PATTERN LETTING UNATOMIZED FUEL DRIP INTO THE CRANKCASE PAST THE RINGS. DON'T WORK IT TOO MUCH AS THIS CONDITION WASHES DOWN THE CYLINDER WALLS AND CAN LEAVE NO OIL FILM FOR THE RINGS TO RIDE ON
Gunner
09-03-2006 16:34:17
The most likely place would be the fuel pump. They have an internal seal that goes bad and puts fuel in the ingine. It is easy to change and far less costly than starting with the injector pump.
Gunner
DanD.
09-03-2006 11:49:10
Probably a leaking seal on the injector pump drive shaft. Is this a Roosa Master pump?
old
09-03-2006 11:48:54
Is it gas or diesel?? If its diesel then you could have bad seals in the injector pump or if it has a fuel pump the pump could be going bad. Either one or both can do that. By the way don't run it till you find the problem or you can lock the engine up. If its gas then it could also be a fuel pump if it has one or a problem with the carb, again don't run it or it can lock up. BTDT
Tx Jim
09-04-2006 03:39:23
 Re: JD 4320 Making Oil? in reply to old, 09-03-2006 11:48:54
Old,I think there were no 4320 gas tractors made only diesels. Tx Jim
old
09-04-2006 08:11:22
 Re: JD 4320 Making Oil? in reply to Tx Jim, 09-04-2006 03:39:23
The 4320 is one I don't know much about as far as the tractor but for the most part an engine is an engine so I just gave him ideas. Thanks now I know just a little more about that one
