jdemaris
09-03-2006 19:24:09
Re: 1020 Diesel Still Satlling at full throttle in reply to Frank in Wv, 09-03-2006 10:16:30
I haven't taken the time to search through all your previous posts, so some of my comments are probably redundant. Usually, the #1 problem with exactly the symptoms you describe is the housing pressure regulator valve with a piece of rubber stuck in it. It is on top of the injection pump assuming you have a DB or JDB style pump. Have you removed it and tried running the tractor without it? I had mentioned it back in August. If you haven't, there's not much sense going on to other possibilities. Your tractor does not need the fuel transfer pump to run - it will do fine without it. But, without it, it's pretty hard to do a filter change. Now, if the fuel transfer pump has blockage - that's a different story. It does NOT have to pump, but fuel must at LEAST get through it. The Roosamaster/Stanadyne fuel injection pump has its own fuel transfer pump built into the back of it and will draw its own fuel, and the other pump on the side of the engine, is more or less, a convenience item to make priming and filter changing easy. One note though, the original is supposed to have a hand-primer lever on it. If you are attempting to check it, do NOT check it with the hand primer lever - only check it by cranking the engine. Also, I assume you made sure fuel is getting out of the bottom of the tank okay. Back to the fuel-pressure housing regulating valve on top of the DB or JDB injection pumps. When it plugs due to internal failure of a vibration dampener, the tractor will peter out - but once it dies, it will start right up again. Also, a note about diesel bacteria that you mentioned previously. Putting a biocide in your fuel will stop further bacteria activity, but won't get rid of them. The black stuff that plugs filters is live or dead bacteria. Biocide kills them, but their little dead bodies still plug filters just as well.
