955 reverse noise
Jake Ameel
09-03-2006 09:23:55
I purchased a used 955 hydrostatic drive about 6 years back. While moving some dirt it started making a sharp clicking to almost grinding noise when going into reverse. It tries to move when it's making that noise and occasionally it will grab normally and move.Everything acts normal in forward.
Any ideas??
Thankyou
Jake Ameel
Metamora, MI
Plant Doctor
09-03-2006 16:15:41
 Re: 955 reverse noise in reply to Jake Ameel, 09-03-2006 09:23:55
Jake: Does it do this in both high and low range? If so, my guess is the bevel pinion could be walking back and forth. When going forward, because of the way it is bevelled, it gets sucked into the ring gear, but going backward it gets pushed out of ring gear. Or where you shift it to front wheel drive, rear wheel drive, it is not going completely into gear? Fit, what do you think about this? I know you have an 855, they should be very similar.
Jake Ameel
09-04-2006 07:22:20
 Re: 955 reverse noise in reply to Plant Doctor, 09-03-2006 16:15:41
It makes this noise in low and high. When traveling in forward or down a slope it makes the same noise when I release the forward pedal and doesn"t "hydostaticly" slow down.
Plant Doctor
09-04-2006 12:44:49
 Re: 955 reverse noise in reply to Jake Ameel, 09-04-2006 07:22:20
Jake: When going forward down a slope in 4wd, will it hydrostatically slow down? If it will slow down in 4wd and not 2wd, then I still think it could be in that bevel pinion gear?
Jake Ameel
09-04-2006 16:16:00
 Re: 955 reverse noise in reply to Plant Doctor, 09-04-2006 12:44:49
No, It makes no difference whether or not it is in 4 wheel drive. It still does not slow down hydostaticlly. But, you may be on to something. I have been studing the exploded diagrams on John Deer Parts and there is one pinion gear that is on the output shaft of the hydrostatic pump/drive unit that drives the rear drive/pto/4 wheel gear box. IThe gear is held on by a single bolt in the end of the shaft. I can't see the physcial connection on the diagrams but hopfully that could be the culprit.
Plant Doctor
09-05-2006 04:54:23
 Re: 955 reverse noise in reply to Jake Ameel, 09-04-2006 16:16:00
Jake: Sorry I didn't get back to you sooner, for some reason a message appeared saying I need a password??? I have a tech manual for an 855 which I think has the same final drive setup as the 955. I will read it over and see if anything jumps out at me. My suggestion is you drain the hydraulic oil and check for metal shavings. This may tell you if the problem is inside or possibly outside the case.
F-I-T
09-03-2006 09:48:23
Jake:
Just a really wild guess, but is the diff lock hanging up and partially engaging on reverse? I think that might make a clicking sound if you try to engage it as you are changing directions.
Frank
