FWA tire size-ratio question
Dan(-Midwest
09-03-2006 08:01:43
I have a JD 5520 that I replaced the tires on. I used the same size that was on there but used radials. There is a relatonship between the size of the front and size of the rear and you have to get it close, I think,or you can mess up the transmission. The tractor came with a front to rear tire ratio of .77 and the factory suggests .74. On newer tractor models I have seen factory mounted different size tires that give a .725 ratio. My radials give a .79 ratio. Anyone knw about this to tell if my .79 is too far away from factory suggested .74? I could swap the front radials back to bias and have a .74 and I'm thinking of doing that.
leon
09-04-2006 05:54:48
 Re: FWA tire size-ratio question in reply to Dan(-Midwest, 09-03-2006 08:01:43
By newer tractors, I presume you're talking about newer of the same make and model as yours. Both front-to-rear axle gear ratio as well as tire sizes have to be taken into account when figuring MFWD tire size. Then too, you should be looking at tire loaded rolling radius, or diameter, or circunference, to do your calculations. The factory suggested ratio of 0.74 takes all this into account for a front wheel overspeed most likely in the 3 to 6 percent range. 0.77 or 0.725 may be close enough to the nominal 0.74, but your current 0.79 ratio may be getting outside the desired ratio range and you'll end up scrubbing off your front tires pretty fast. Your dealer should be able to tell you if the tires you now have on are OK.
DAN9-Midwest
09-05-2006 18:20:39
 Re: FWA tire size-ratio question in reply to leon, 09-04-2006 05:54:48
leon--I don't mind scrubbing off the front tires but the dealer mentioned he heard something about "loading" the transmission and causing problems. He wasn't sure.
I called JD and they said ".741". When I explained their tractors came through at .72 or .77 and that .741 was not possible in ANY tire combo out there, they said they would call back. I'm still waiting.
Any ideas on this?
leon
09-05-2006 18:36:02
 Re: FWA tire size-ratio question in reply to DAN9-Midwest, 09-05-2006 18:20:39
Yes, I suppose it would load the drivetrain unnecessarily, especially in good tractive conditions like concrete, but who runs with MFWD engaged there anyway.
Sorry I can't be of further help but don't have the specific information needed. Bug the JD guy if he doesn't call back in a reasonable amount of time.
