Hey Gerald J.
hunter
12-12-1999 11:59:37
went out to the shed few minutes ago and carb. was wet. loostened the air pipe and probably a half teaspoon of gas ran out. what should i do? i had a kit put in it just a few weeks ago. thanks
Dan
12-12-1999 15:47:56
 Re: hey Gerald J. in reply to hunter, 12-12-1999 11:59:37
Did you turn the fuel off when you last ran the tractor? Never trust the needle and seat or the float. A small flack of rust or something can not let the needle close off in the seat. You may need to check the float or the needle and seat for the leaking fuel. But please dont trust the float or the needle and seat. Turn the fuel off next time. No worries then.
hunter
12-12-1999 15:55:07
 Re: Re: hey Gerald J. in reply to Dan, 12-12-1999 15:47:56
Dan, on the to-30 ferguson i once owned i had the same problem only mush worse. shutting off fuel was my only fix on that one. thanks
