4020 3pt
j. d. meyer
09-02-2006 15:51:23
3pt wont stay up whe i shut the tracter off on my 65 4020. is there some adjustment i could do to help this or is it time for jd mechanic. thnx jim
Steve in PA
09-05-2006 06:37:49
 Re: 4020 3pt in reply to j. d. meyer, 09-02-2006 15:51:23
I just fixed that on my 68 4020 behind seat if you look there is a plate that holds up the top link if you take it off there is a piston behind there one o-ring and one seal on it $14 for both a fairly easy fix. The only thing is you lose about a gallon of oil when you pull the piston out. The o-ring goes on first then the seal goes right on top the o-ring.
Glen in TX
09-02-2006 22:18:23
Just leaking piston and seals. Kind of normal actually. If it still works enough to get the job done what you need it for leave it alone. For safety reasons and a heavy implement on 3 point you should park it with it down anyway. If it bugs you and you got the $$$ to spend fix it.
