49 JD A smoking at the clutch Two part question
Scott Griffith
09-02-2006 14:33:36
Part I
We turned some bottom land with the 49 A today and noticed that it has been blowing white smoke from out around the clutch pulley. What causes this to happen? Is it a bad seal that needs replacing?
Part II
When I make a turn I notice a grinding noise coming from around the rear axle / bull gear area. What generally happens to cause this noise and what should be done to repair it?
Thank you,
Scott
billpa
09-03-2006 06:46:27
 Re: 49 JD A smoking at the clutch Two part questio in reply to Scott Griffith, 09-02-2006 14:33:36
The smoke comming from clutch is blow by caused by compression getting past the piston rings.
The noise comming from the rear is bad spider gears should be fixed right away befor more damage is done
