49 A clutch noise
ol' guy
09-02-2006 13:52:57
My newly overhauled "A" has a scraping/squeaking noise in the clutch area, but only when the clutch is disengaged. Friends (and the mechanic who did the engine work) tell me that it must be either the driving disk or the bearing(or race) behind the driving disk. Both the driving disk and the bearing look o.k. What else might it be?
Thanks for the help.
Glen in TX
09-03-2006 09:16:54
 Re: 49 A clutch noise in reply to ol' guy, 09-02-2006 13:52:57
Look to see if the dust shield behind clutch pulley is out of line or loose and pulley is rubbing on it? That can make quite a squeal too! If it is someone has to pull it all off and realign the cover. May be a combination of too much crank end play and a cover out of line or other worn clutch parts or pulley brake not adjusted right too.
ol' guy
09-03-2006 15:14:40
 Re: 49 A clutch noise in reply to Glen in TX, 09-03-2006 09:16:54
Glen- Thanks for the suggestions. We will check out the items you mentioned next week. If any more ideas surface, please inform. Thanks again!
