2955 hydraulic problem
Plant Doctor
09-02-2006 06:54:20
Tractor and hydraulics work fine until everything gets hot. After the oil gets hot it loses ALL hydraulic functions and I mean ALL. I removed and cleaned the sump screen and filter which made no difference. I separated the trans and rear and installed a new oil pump that supplies the main front hydraulic pump which made no difference. The front pump was changed by Deere and it still does the same thing. I am getting close to the price of a used tractor!! Any ideas? Thanks in advance.
Tx Jim
09-04-2006 04:13:49
 Re: 2955 hydraulic problem in reply to Plant Doctor, 09-02-2006 06:54:20
Remove hyd filler cap,with engine running and warm look inside hole with light for spraying oil. Also feel of each hyd component for excessive heat. IMHO dealer should have done better diagnostic work before replacing expensive parts. As B&D stated checking hyd. flow is a good way also. Tx Jim
buickanddeere
09-02-2006 10:43:08
I recommend trouble shooting and diagnosis rather than throwing random parts at a problem. Could have done a flow test with a couple of hoses, a pressure gauge and a valve. And bought a couple of plugs to test by halting flow to the rockshaft/remotes and to the power steering.
Plant Doctor
09-03-2006 05:18:53
 Re: 2955 hydraulic problem in reply to buickanddeere, 09-02-2006 10:43:08
Buickanddeere: You are 100% correct and I agree, but in this case Deere did the diagnosis, gave me a couple of things they recommended me doing. If you noticed, I did send it to Deere later on when I gave up and they installed the new pump that supposedly was to solve this problem. Looking back on this, I guess I should have sent it to Deere to start with and let them have the entire problem. But I will bet you that I would have more money tied up in than I do now and maybe still have the same problem. The tractor is just old enough and has enough hours on that Deere has a million excuses why they will not stand behind their work. Pump, for example, they are saying it needed replacing and maybe it did, but it sure didn't solve the problem. Deere copied their hydraulic trouble shootng information for me. I read the entire thing several times, but I can't say it was specific enough in any one area to pinpoint the cause. But you are correct, I just don't know how to get it diagnosed without breaking the bank or how to get anyone to stand behind their diagnosis?
cannonball
09-02-2006 09:22:09
got high pressure leak somewhere..probably rockshaft...
