Carb adjustment on gas 3020
Illinois Farmal
09-01-2006 18:33:52
I have a gas 3020 that seems to be running a little on the rich side. I don"t have a manual for it yet and was wondering how to adjust the carb for this. I"m new to the "green" machines and don"t want to make it any worse than it already is. Thanks.
Gerald J.
09-07-2006 22:56:53
 Re: Carb adjustment on gas 3020 in reply to Illinois Farmall, 09-01-2006 18:33:52
There are several things besides carburetor adjustment that will make the gas engine run rich. I found most of them in my gas 4020 several years ago.
1. The domed top of the Donaldson precleaner was domed down instead of up. That restricted air, partly choking the engine.
2. A dirty oil filter will restrict air and make any carbureted gas engine run rich.
3. The choke cable sheath wasn't anchored near the carburetor and that kept the choke from opening more than half way. So it ran rich.
4. The float needle and seat were worn so the gasoline level in the float bowl was high, that made it run rich.
The high speed adjustment on the Zenith carburetor is in the middle of the idle shut off solenoid and on my 4020 is almost impossible to adjust.
5. Mud dauber nests and birds nests in the intake lines before and after the air filter can contribute to choking the engine and making it run rich.
Fix all those other things before you mess up the carburetor settings. The M-S carburetor is much harder to set, so much so that Deere recommended replacing it with the Zenith in a 1970s vintage service bulletin. I think a leak in the diaphragm under the rectangular cover can also cause rich running of that carburetor.
Gerald J.
J. Brock
09-01-2006 18:45:36
The manual for my uncles 3020 gas says idle adj. screw (top one) is 1.5 turns open. Load mix. screw is 1.5 turns open for a zenith carb. and 2.25 turns for a marvel-schebler
Bob
09-02-2006 12:43:06
 Re: Carb adjustment on gas 3020 in reply to J. Brock, 09-01-2006 18:45:36
Unfortunately, due to manufacturing tolerances, wear, and use in various altitudes, the settings given are as an initial guide ONLY.
You may have to "tweak" the settings considerably from those numbers to get it to run correctly.
