Final on Alternator question
Osage
09-01-2006 08:10:34
O.K., thanks again to all for all the info.
Now here's the results----
Yes, there is a strong magnetic response on the back of the Alternator anytime the key is on, whether the engine is running or not.
Over the full range of RPM's the voltage remained constant on the dash mounted Voltage gauge and my Fluke Voltmeter.
However, after performing the full field test(grounding the test hole), the Alternator started charging. Even though I seem to be able to control the voltage within range using lights & accessories, I think it will again slowing raise the battery voltage to an unacceptable level under high RPM's.
So, it sounds to me like its a defective Alternator.(Agree or Disagree?)
Osage
Osage
09-01-2006 12:30:29
 Re: Final on Alternator question in reply to Osage, 09-01-2006 08:10:34
Well I guess I spoke too soon, as stated earlier following a momentary grounding at the test hole the Alternator ran the voltage up to about 16volts then quit charging totally.
The voltage dropped back to the 12.43 battery level.
Additional test hole momentary grounding results in no change in voltage.
Osage
Lee B
09-02-2006 00:02:04
 Re: Final on Alternator question in reply to Osage, 09-01-2006 12:30:29
Test hole grounding most likely burnt up your 6 main rectifying diodes but there are other possible reasons of why you now need another alternator?
Momentary grounding in the test hole is supposed to NOT exceed one half of one second. Only enough time to hear the alternator grunt or simply note that your voltage is rising - you NEVER 'see what she can get up to' or obtain a maximum voltage reading of any kind, that's exactly NOT what that hole is for.
Bob
09-01-2006 14:40:35
Here's a diagram of the internals of the alternator:
Third Party Image
Likely, the internal voltage regulator may be bad, but defective diode trios or rectifiers can cause weird problems, too!
