47 A starter trouble
pajoe
08-31-2006 17:34:23
My 47 A has made some starter noise a few times recently. Tonight I went to move it inside because of the coming rain and when she started the starter did not retract and disengage from the flywheel. I shut her off and took the flywheel cover off. I can move the starter gear onto the flywheel, but it snaps back under tension. I put it on the flywheel and started her again, same deal, did not disengage when the tractor started. What might be the problem?
Fred from MO
09-01-2006 09:18:08
 Re: 47 A starter trouble in reply to pajoe, 08-31-2006 17:34:23
I have a 53-60 that after a rebuid of the starter did the same thing. The contact switch on the starter would weld the leads together. I never did figure out why that one switch would do that. Some people on the site told me low voltage would cause this to arc and weld them, however my battery was in good shape. I wound up putting the old contact back on my rebuilt starter and I have never had a problem since. I would check your contact on your starter. Unfortunatly you will have to pull your starter for this. It should be similar to a 60. It is not too hard, but it is heavy-so use your knees legs and chest to heft the thing down.
Hayfarmer
08-31-2006 18:46:17
I'd say either a problem with bendix spring or maybe teeth that are hanging up due to wear or burrs. Pull the starter off and look at it.
