JD 310a Ring Gear
Patrick Bourgeo
08-31-2006 17:30:44
Hi, I need a little information if possible.
I have a JD310a 1976 (4 cyl diesel) I need to replace the ring gear, do I need to split the tractor in half or I am able to find enough room to remove the fly wheel by just backing off or a few inches ? If I have to split the tractor in 1/2, do I need to remove the cab and or the front bucket?
Thanks for your time.
Best Regards
Patrick
Patrick Bourgeois
09-01-2006 18:55:31
 One more question ! in reply to Patrick Bourgeois, 08-31-2006 17:30:44
WOW !! Fast service :)
Big thanks to all, it�s really appreciated. I will probably split the tractor this week end, only one more question, in fact two... For the average mechanic (automotive in my case) how many hours are requested for that little job :) And whre can I buy the Shop Manual ?
Best Regards To All
Patrick
Patrick Bourgeois
09-01-2006 03:25:13
 Re: JD 310a Ring Gear in reply to Patrick Bourgeois, 08-31-2006 17:30:44
Best Regards To All
Patrick
Jonathan in MA
08-31-2006 18:17:11
Yes, you do have to split the tractor... and no , to do that you dont have to remove the cab or bucket.. raise the loader all the way up.. chain the bucket so it doesnt roll out.. and install a locking bar(s) on the boom cylinders to support the loader while you are working under it.. support the side frame bars in the area under where the boom cylinders attach (backhoe resting on the ground) and you can roll the front section away supported by a floor jack or an overhead crane if you have that luxury.. best done on a flat level surface.. It seperates at the bellhousing to engine block joint. Also wedge some blocks between the top of the axle and the front frame so the engine doesnt tip sideways when it is rolled clear of the rear half..
Tom in Central Pa.
08-31-2006 18:13:57
The FIRST recommendation is to buy a manual. You do NOT need to remove the cab, or the loader. I always put the loader blocked UP. I put a 2X4 block in each side of the the frame below the radiator, so the front assembly stays level. I put a floor jack under the engine, and rolled the front half away from the back. I set the side frames on jack stands. Use a "bottle" hydraulic jack to support the bellhousing. Disconect hydraulic lines, etc remove bellhousing bolts etc.etc. etc.
Tom in Central Pa.
08-31-2006 18:13:07
