A/C JD 4630
Ltfox
08-31-2006 15:41:36
K, I found this a/c pump
Link
Is this what I need for my 4630. also is this a 134a compressor or r-12??
Thakns
Layne
G/MAN
09-01-2006 07:43:42
 Re: A/C JD 4630 in reply to Ltfox, 08-31-2006 15:41:36
It's never a bad idea to remove and replace the expansion valve while you've got the system evacuated. And since the sensing line for the valve can sieze to the evaporator, be looking for that potential problem also. Fortunately Deere offers a replacement nipple that a competent welding shop familiar with aluminum welding can install. Otherwise you're looking at replacing the evaporator. And if the system has been discharged (empty) for any length of time, flushing the lines out isn't a bad idea to remove any moisture or debris. For sure you want to if the previous compressor had a catastrophic failure. Pulling the vacuum on the system will boil the moisture out of the system, but it's much better to start with a clean system. And replacing the receiver-dryer is an absolute must. The small amount of dessicant in them is quickly saturated when a system is open to the atmosphere. We also like to pressurize systems with 250-psi of dry nitrogen to insure they'll hold pressure and not just vacuum. There are also steel lines running up the LH rear cab post that can and will rust out on older tractors, creating a leak that's impossible to find without pulling the outer cover off the post. And look at all the other fittings and hoses while you're at it. It's usually cheaper in the long run to repair the system correctly than to go back time and again to replace a line here, a stuck expansion valve, etc. Also consider charging the system with dyed refrigerant, as that makes future leak finding much easier.
cannonball
09-01-2006 04:09:50
yes same number that i have on 4230..mine said murry 57078...coil at 10 oclock and super heat plug you will need dryer from deere..you will need to put in correct oil for the freon you use and remember you need to flush system and put in new expansion valve and most of all pull a vacuum for proper time..you can get ac pump form a&i but mine did not last..also had problem got wrong pump and finally got right one but ended up paying shipping for sending the wrong one back, had some butt that was over a&i got mad cause i brought it to their attention that the coil was in wrong position...they pulled all pumps and send them back to their remanufactor.. so trying to save someone from getting the wrong pump cost me...lol you can take this number 57078 to o'reillys and get pump ...have nice day MAY GOD BLESS USA
Glen in TX
08-31-2006 16:22:18
Probably not?
https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.servlets.searchcontroller.EquipmentSearch
Part Details Part Number: TY6770 Part Price: 385.20 USD Core Value: (21.00 USD) End Price With Core Return: 364.20 USD On Hand: 11 Check Other Stores Description: REMAN A/C COMPRES.(SER.FOR RE60697
