1929 D carburetor adjustment help
bmklawt
08-31-2006 00:41:19
I have a DLTX 3 that was rebuilt by Branson? about 10 years ago and it has only been run about 2 hours for the first time recently.
My initial setting on the carb were Load 1 turn out, Idle 2 turns out. The tractor starts hard and it spits out a lot of black smoke and dirty oil (at least I think its oil) comes out from around the idle screw until it is warmed up. It also drinks about a gallon of gas every ten minutes while idling much less while driving.
I can turn the idle screw from closed to 3 turn out and the Load form closed to 2 turns out with no effect on how the tractor runs.
It runs a little better with the air filter in that when it�s out, I still use the original horse hair filter.
I thought the oil leaking through the idle screw might be from exhaust blowing back into the carb so I machined the bottom of the manifold flat and installed a new gasket that, didn�t help.
Any ideas why I�m getting oil thru the idle screw and why adjusting the load and idle screw does not effect how it runs?
Thanks for the help,
Bruce
bmklawt
09-12-2006 07:22:35
 Re: 1929 D carburetor adjustment help in reply to bmklawt, 08-31-2006 00:41:19
Correction to first post: It leaks around the LOAD screw and only when running.
Sorry for the long delay in posting back. I only get a chance to work on the tractor on Sundays.
Glen in TX, Thanks for the information, I do have the DIR108 manual.
P Browning, I did follow the direction for testing IDLE & LOAD pathways. And it checked out as the direction said it should.
I also checked the cam timing.
Adjusted the tappets, took all play out and backed screw out � turn.
Adjusted magneto (Edison Splitdorf 246C) to fire a TDC, also tried a little before and after, I also gaped a spark plug to 3/16� and get a blue spark.
Took carb apart and checked all passages and checked float for 5/8� setting.
My observations: with magneto set to fire at TDC or a touch before, spark advance all the way back, throttle closed, lots of carb cleaner (as starting fluid) in the compression relief valve, it will start after 30-45 minutes of pulling on flywheel.
Before the first time I started it, it ran backwards for a second.
It leaks gas out of the bottom of the front butterfly valve and I can see where gas is leaking back into the air cleaner until started, it seems to leak more just before it starts that at other times.
It drinks a ton of gas, more so at idle than when it�s driving? It still spews black smoke at idle and adjusting the idle needle does not seem to help, While driving in the yard the black smoke is considerably less, although there is a pop every second or so accompanied by a bigger puff of smoke.
I did walk along with the tractor while it was being driven and turned the idle needle all the way in and did not notice much difference in the way it ran until it was almost closed, I also did the same with load needle.
I did forget to check for vacuum leaks around carb and manifold.
Questions:
Does something go on the choke? Right now there is a spring on the choke that holds it open.
Would a hotter plug help or hurt?
Does it matter which gas I use, regular, premium?
Your help in this matter has been much appreciated.
Bruce
Glen in TX
08-31-2006 08:47:17
Pull the bowl off and see if it has the cork float? If so and been 10 years the float probably needs resealed or better yet find a brass float to go in it and toss the cork one. It's going to run way too rich if that cork float doesn't do it job right. That's first thing I would look at and where I would start on it. Then post back if other problems. Spiders or bugs could have built a nest inside a passage way with it sitting that long too and plugged something. The DIR3 or DIR108 or SMF116 manuals for early D will give you carb settings.
P Browning
08-31-2006 08:40:09
Bruce -- I am by no means a guru for JD-D carburetors, but I think I can help you get turned in the right direction. Your notes that those needles have little or no effect on engine operation are not encouraging. Also, you indicate very little engine time since some ten years back when you had the carb worked. Modern era gasoline is no friend of your antique JD tractor when it is not being worked.
Let's begin with two simple no-wrench tests to see if some part of that carburetor is blocked with gum residue, rust or a combination of the two.
Go to the JD-H Restoration Site (below), and then one-click on CARBURETORS over on the left side. Allow time for the PDF document to come up, then proceed to page 7 where you will find an outline of testing -- IDLE & LOAD Pathways. I ask that you run those tests and post back with the result & we can take it from there. 'Lots of JD-D fellows on this forum, and they will come in to help. (PatB)
bmklawt
09-12-2006 20:11:51
 Re: 1929 D carburetor adjustment help in reply to P Browning, 08-31-2006 08:40:09
I
