44 A charging problem
greenmech
08-30-2006 20:27:40
12volt generator,negative ground system.shows discharge when running. Lights also show discharge when turned on.Have polarized generator and believe the wiring is correct. Is it possible the regulater is the wrong polarity? Generator was checked at a shop, and was good. Ron Mn.
John T
08-31-2006 07:31:05
 Re: 44 A charging problem in reply to greenmech, 08-30-2006 20:27:40
Ron, Most Voltage Regulators will work at either Pos or Neg ground and its the genny that gets polarized NOT the VR.
First of all you may wanna re polarize the genny just in case you didnt get it right, as Pappy mentioned I covered that in detail a lil down below.
Next thing that comes to mind is that tractor was originally Positive ground and if you converted to Negative and did not reverse the ammeter by swapping its leads, IT WILL READ BASS ACKWARDS i.e show charge when its really discharging but show discharge when its actually charging.
Turn the lights and/or ignition on NOT RUNNING and if the ammeters wired correct it should swing over to - discharge, but then when running (if wired correct and genny works) it should swing over to + charge ,,,,, ,,,,if it does just the opposite, reverse the ammter by swapping wires over to the other terminal.
Even if the ammeter is wired backwards or dont work she could still be charging. Place a voltmeter on the battery not running and she ought to read around 12.6 volts,,,,, ,,,then when runnign at high RPM if shes charging the battery voltage ought to rise to the 13 and 14 volt range. Also if shes charging the lights would glow noticebly brighter from idle to wide open. IFFFFF FFFFF SHE DOES ALL THAT SHES CHARGING FINE SO MAYBE THE AMMETER IS JUST WIRED BACKWARDS
Also if its a coil ignition and you reversed from the factory original positive ground, the coil leads need reversed.
If the battery were changed polarity and the genny NOT correctly re polarized and you fired her up, you could have damaged the VR !!!!! !!
If you need more troubleshooting tips post back but for now Id polarize and do the ammeter checks above to see if its wired correct and do the voltage and lights checks above to see if she actually charging or not, then post back your findings and more questions.
John T
greenmech
08-31-2006 09:50:12
 Re: 44 A charging problem in reply to John T, 08-31-2006 07:31:05
John T thanks for replying. Did some more testing. Removed and grounded Field wire from generator, got + amps on gauge.At the same time got a voltage reading on A terminal to ground of about 14 volts. Lites do not get brighter on high engine speed. Thinking now a bad regulator.Ron Mn.
John T
08-31-2006 10:15:52
 Re: 44 A charging problem in reply to greenmech, 08-31-2006 09:50:12
Sounds like youre gettin there. If it charges as you say when you dead ground the gennys Field post, its EITHER a faulty VR as you mentioned,,,,, ,,,or the VR isnt well grounded (usually to the gennys case),,,,, ,,,,or the wires bad from the gennys Field post to the FLD terminal on the VR.
John T
greenmech
08-31-2006 10:41:34
 Re: 44 A charging problem in reply to John T, 08-31-2006 10:15:52
John T. I'll check the ground to the VR, then off to the store . Thanks again for your help. Ron Mn.
Pappy
08-30-2006 21:12:39
Go down about three posts and read John T's explanation about polarizing a generator. This could be your problem.
