Hydraulic and MFWD ?
Eddie Jones
08-30-2006 19:18:15
I have a couple of question. What does it mean when they said it closed or open hydrualic, and what does MFWD mean? Thanks Eddie
K.B.-826
08-30-2006 19:48:26
 Re: Hydraulic and MFWD ? in reply to Eddie Jones, 08-30-2006 19:18:15
With open-center hydraulic valves, oil flows from the pump, through control valve, and back to the reservoir whenever the control valve is in the neutral position. With closed center hydraulic valves, oil does not flow through the valve when it is in neutral. Either there is no oil flow, as in most Deere tractors, or the oil goes back to sump through an unloading valve like the old 460/560 IH's which had closed-centered valves. Deere tractors, like the 4020, have a piston pump. the pistons are forced up to pump oil by a shaft that has a lobe similar to a lobe on a camshaft. When all control valves are in nuetral, pressure in the system builds up to about 2300 psi. The pressure moves the stroke control valve over, which allows pressure oil into the pump crankcase, which forces the pistons up and away from the driveshaft, and oil ceases to flow. This saves power. The old 60 series IH's used a gear type pump. When the valves were in neutral, pressure builds up and opens an unloading valve, which directs the flow of oil from the pump back to the reservior.
MFWD stands for mechanical front wheel drive. In this system, the front axle is driven by the transmission through a driveshaft. Another type of front wheel assist is PWFD- power front wheel assist. The front wheels are driven by hydraulic motors. You'll see this type on 40 series and older Deeres.
