HEISLER HEAD INTAKE
DON
12-11-1999 22:50:17
WHAT HP CAN I EXPECT FROM A 1951 JD A WITH .045 OVER ALIMINUM PISTONS AND A 71 CARB WITH A HEISLER HEAD AND INTAKE WITH 38 BEING FACTORY HP
al
12-12-1999 15:31:32
 Re: HEISLER HEAD INTAKE in reply to DON, 12-11-1999 22:50:17
Don,
A friend has a 41 A with similar set up but, around 250 psi compression. Said he made 58hp before it blew the head gasket.
DON
12-13-1999 23:11:21
 Re: Re: HEISLER HEAD INTAKE in reply to al, 12-12-1999 15:31:32
DO YOU KNOW WHAT COMPRESSION RATIO THIS GAVE YOU AND COULD YOU RUN REG GAS
Chad WInk
12-12-1999 17:25:43
I had a 48 A with this head and M&W Add Power pistons. I also had the head gasket problem.. I resolved it by removint the studs, and using grade 8 bolts that was the end of it blowing the gasket. I also used SEVERAL coats of Permatex on it.
