Belt Pulley cover won't stay on
ol' guy
08-30-2006 15:02:59
Just finished restoring a '49 "A". It "throws off" the beltpulley/clutch cover in just a few minutes after starting it. Any suggestions??
It's a reproduction one-- not Deere. If I end up havint to buy another one, who sells a good one that will stay on??? Thanks for the help.
Duane Larson
08-30-2006 20:09:46
 Re: Belt Pulley cover won't stay on in reply to ol' guy, 08-30-2006 15:02:59
ol' guy,
I know the problem - I ran over a repro with my steel-wheel AR when discing. Some of the repro covers had a problem, particularly the ones without a dimple in the center. Detwiler now has a good one - saw them at Portland and bought a couple. They have the proper holes and size for the clips - but as others noted make sure your clips are ok. If you need one you might call Detwiler at 1-715-659-4252 and ask for the cover with the dimple in the center.
bobinks
08-30-2006 17:34:13
I had a similar problem. In my case the three clips were still on the inside of the pully but the tips of two of them were broken off. It took me quite a while to come up with an idea of how to hold the rivets in place without removing most of the clutch. I ended up using one of the old clips and a pair of visegrips to hold the rivet in place while I peened it over. Hope it helps.
F-I-T
08-30-2006 15:23:01
OG:
Are the three clips in place on the inside of the pulley? Are you guiding the cover on so that the three flats are under the nuts? Is any of the three adjusting bolts sticking out and bumping the cover, encouraging it to take flight?
Frank
RalphinWI
08-30-2006 18:32:25
 Re: Belt Pulley cover won't stay on in reply to F-I-T, 08-30-2006 15:23:01
Too emphasize what F.I.T. has said I think more than one, (myself included, thankfully in my earlier days) has put the cover on so the flats meet the clips. This means the clips don't get a good grip on the cover. When installed this way, I suspect (but don't know for sure) that the nuts or cotter keys can snag the high spot in the rib and push the cover off while the clutch is operated.
