70 d power steering
stu in njo
08-30-2006 11:39:44
At low rpm it steers fine to the right but is slow & hard to the left at road seed its better.Thanks for any help Stu
Glen in TX
08-31-2006 09:03:18
 Re: 70 d power steering in reply to stu in njo, 08-30-2006 11:39:44
Like Al said the I&T shop manual will cover most of it well enough. The JD SM2050 Power Steering service manual does get into more details if you have to overhaul more of it later. Centering it like Al describes is a commonly overlooked problem on many of them and most people were too lazy to remove the grill and tend to what needed to be done on servicing them in the past like changing the oil in the system also and flushing it using the JD power steering oil. This site and others sell the I&T manuals and JD will have the SM2050.
buckeye al
08-30-2006 14:56:55
It may be as simple as the valve body at the top of the steering pedestal needs to be centered about the operating valve's operating range. That's an easy operation that involves only removing the grille, loosening the 4 cap screws that hold the worm & valve housing to the pedestal then with the tractor running, use a hammer to tap the valve body forward or back until operation is uniform each way. A little movement can make a lot of difference! I have the best luck with this if I jack the front wheels up off of the ground while tapping but put it back on the ground to test from the seat!
You MAY also note that if you push forward on the steering wheel it will steer easier one way than the other & if you pull back on it, the easy direction switches. This actually is a good indicator that for the most part only adjustments are needed but they're a bit more involved than just centering the housing above.
If this pushing and pulling makes a difference, it is likely that the bearings need adjustment on the worm shaft in the valve housing. If adjusting them though, you probably should at least check and maybe (only if needed) adjust the actuating valve's travel. The adjustment for that is made inside the valve and worm housing behind a 3/8" pipe plug at about 1 o'clock near the rear end of the housing when viewed from the seat. Inside is basically a set screw on the steering shaft so you have to do a bit of hunting to find it. Adjust it ONLY AFTER temporarily removing all of the runout in the bearings of the worm. Best use a dial indicator! I don't remember what the setting is but it's only something like .010". Will look it up if others don't quote it first! Stake it when done! Next you set the worm shaft bearing runout which is only like .002" or so max. Again can look it up if you want. Lastly start it and center the valve body like listed above.
These operations are not particularly difficult but they DO need to be done in order and some small differences can make a big difference in performance. The best suggestion I have is grab a book! I believe the IT manuals do a pretty good job of stepping through this process!
I'd first try just centering the valve housing ESPECIALLY if pushing and pulling on the steering wheel does NOT make any big differences!
Later.
