JD 435
Tom Weidner
08-29-2006 12:27:26
i'am tring to pull start + one wheel goes one direction the other opposite,i was told there's some type of locking device in the trans, is this true
MSD
08-29-2006 21:25:38
 Re: JD 435 in reply to Tom Weidner, 08-29-2006 12:27:26
Anyone know where I can find a good block for a 435?
JD@Antique Acres
08-31-2006 07:59:54
 Re: JD 435 in reply to MSD, 08-29-2006 21:25:38
I have a bare block that I bought a few years ago that I might be willing to sell.
buickanddeere
08-30-2006 15:41:16
Old motor welders, construction drainage pumps and some refer gen sets. Tired 440ID crawlers needing $10,000 in under carage work often become donors. I would look anywhere except for another 435 to find an engine. I made a 2-53 head from a 4-53 head but I'm not saying any more than that.
Mike M
08-29-2006 13:16:55
Either your engine is locked up or your in too low of gear. Try high gear. If your engine is locked up from rust or antifreeze you may break stuff pull starting it.
buickanddeere
08-29-2006 15:05:56
 Re: JD 435 in reply to Mike M, 08-29-2006 13:16:55
Unless you pull from the front of the drawbar. That front end is going to at the least, snap at the center casting. One of my 435s was smashed by a jerk, yanking on it. What is going on? Battery low and trying to start a running tractor? or did you just find/purchase this 435 and giving her a test drag/run? As previously stated, high gear or forgot it. Is the shifter properly marked to show the gears? Detroits are dirt cheap to rebuild. Just tear her down and upgrade the piston/sleeves, springs, blower seal and injectors to the N series.
