74 J.D. 400 backhoe/loader NEED HELP ASAP!!
Donnac
08-29-2006 09:09:34
How can I tell the year of this J.D.Bachoe/Loader. When we bought it, the guy said it was a 74. Now we are selling it and a really nice farmer came to look at it and said it is definelty not a 74, he thinks its a 60's. The thing runs and is useable, but the hydrolics leak so it needs new seals and to be repacked and some of the hoses are cracked, also could use new tires. He also mentioned that the fuel pump is worth a lot because you cannot get it anymore. We are asking $4500 or best offer. He offered us $2000 cash. Opionions????
cannonball
08-30-2006 04:38:54
 Re: 74 J.D. 400 backhoe/loader NEED HELP ASAP!! in reply to Donnac, 08-29-2006 09:09:34
does it have 2 seats, i have a 300b and it has one seat the guy i got it from said that it was first year for one seat and it is 1973..i can assure you he knew had a bunch of them 300 and 300b's..... have nice day MAY GOD BLESS USA
Glen in TX
08-29-2006 15:41:56
There is a serial number list on the Weird Deere site for 400. Were there 2 different 400s made back then? This site says beginning in 65 to 71 yet I have a blue book showing a wheeled JD 400 and says 75-85 ???
Jonathan in MA
08-29-2006 14:47:54
as the other poster stated,.. find a serial number.. its usually on a plate (I think) on the lower left side of the transmission case.. under the floor boards-- in front of the axle... That was "really nice" of that guy to offer 2,000... I'd point out to him the part about "best offer" ... I'd wait for a little more if everything works and its a diesel as u stated.. not sure about that injection pump being worth more.. when it breaks, almost no one can rebuild them anymore and you have to replace with a newer style and all new injection lines.
Mike M
08-29-2006 09:14:34
Darn it all I bet you are far from north central Ohio. You can take the serial number and a JD dealer should be able to look it up for you. I'm not sure where that number is on those ? Try looking on the RH front frame rail and on the rear end housings or maybe on the tranny housing kinda under the seat and see if you find a tag or a flat spot with numbers stamped in it.
