slipping clutch or 620
620 row crop
08-28-2006 22:33:20
clutch is graby and jerky and slipping .Probley needs replaced I think its original .Is deere the place to get them or is the clutch kits in green mag the best place ? Would like oem quality if possible .thanks
Larry Pavlis
08-29-2006 05:33:45
 Re: slipping clutch or 620 in reply to 620 row crop, 08-28-2006 22:33:20
In reference to where you should get parts if you should need them, I purchased a clutch kit from WTR parts for my 620 and the quality is as good as you will find from Deere and about half the cost. Thier ad is in green magazine.
Mike M
08-29-2006 04:36:10
Alot of times the grabby and jerky is just from glazed clutch plates. Pull the clutch all apart and inspect for thin or cracked facings that should be replaced and if your metal plates shine like mirrors I sandblast them. Slipping usually just needs adjusted up tighter if everything is assembled right.
