4010 update, got axle off...
TimS
08-28-2006 22:02:24
I got the wheel off the axle, and unbolted the housing and got it off with no problems.
The inner bearing is shot, and it sort of looks like the triangular frame that has the pinions in it had loosened up on the axle some how, there are scrape marks in the housing and also some teeth marks on the brake plate.
The flat triangular piece of metal that looks like it is supposed to keep that bolt from turning that hold the triangular frame on the axle was in place, is there any way that bolt can turn with that triangular plate in place? That plate really isn't very thick for what it has to do....
TimS
08-29-2006 08:50:41
 Re: 4010 - locktite that big axle bolt? in reply to TimS, 08-28-2006 22:02:24
Should I locktite that big bolt ( 1&1/2 inch head ) that holds the triangular pinion frame to the end of the axle?
I just don't trust that little trangular lock plate. The bolt turned out as if it had some thread lock on it before, and it had a bit of residue on the threads....
I'm in luck, one of the local JD dealers has the bearing and oil seal I need, I will pick those up at lunch and work on putting it back together tonight hopefully....
TimS
08-29-2006 12:16:47
 Re: 4010 - pictures! in reply to TimS, 08-29-2006 08:50:41
Here is a shot of the axle and the housing with a piece of the bad bearing sticking out the bottom:
Link
brad the jd tech
08-29-2006 18:06:55
 Re: 4010 - pictures! in reply to TimS, 08-29-2006 12:16:47
the bolt came loose because the bearings lost there preload. I suggest replaceing all the inner and outer bearings in that axle houseing because you dont want to do this again. the axle has a rolling drag when you tighen the bolt. The lock is there so the bolt doesn't loosen up and fall out.
TimS
08-29-2006 20:21:21
 Re: 4010 - pictures! in reply to brad the jd tech, 08-29-2006 18:06:55
Thanks Brad.
I did put a new inner seal and inner bearing, the outer bearing seemed fine.
I tightened the bolt as specified in the manual, it went back together real well its nice and snug.
Thanks all for the help!
