Bryce: Without a load, that engine will go to fast idle speed without much fuel. You need just a bit of load on it before you will be able to approach WOT on the buttefly. When you operate the throttle using your left hand, hold the governor rod in your right hand. As you advance the speed of the engine, the governor rod should pull your right hand back towards the governor case, as the weights sling outward and force against the yoke on the governor shaft. The faster the engine goes, the more force there should be trying to oull the carburetor butterfly closed. A simple adjustment that is seldom performed is that of the governor rod length. With the throttle in the wide open position, the rod disconnected, the holding the carburetor butterfly wide open, the rod should be 1/2 to one hole short of connecting. By holding the rod short of connecting, and forcing you to pull against the leaf spring on the governor shaft, you remove all free play from the linkage, and then governor can make a change in speed immediately after the weights say to do so. You said you removed the left hand cover and founf the cage bearing. This really isn't what I would call an idler bearing as it carries and centers the left hand of the governor shaft. It needs to be intact and functioning. Many have lost balls from their cages over theyears, and often they are not replaced on time. Sound like you need to get a new bearing. Don't forget about the race, either, as they can go bad, too. The spring-loaded thrust bearing on the other end of the shaft (in a bore behind the distributor/mag) pushes to the left to keep that cage in place. Also, under that cover are several shims that look like gaskets (one certainly fills that purpose) that set the gear lash for the matched set bevel gears on the fanshaft and governor. If yours are set correctly (most by now are not, but they tend to go loose which is a whole lot better than tight which will chew those gears up in short order), then be sure you return all of those shims as found. If you ever remove the governor, that's when you re-set that heel and lash. So, if you can make the engine run correctly without the governor, look at the governor. If it runs poorly or you cannot hold it steady using your hand, you may have a careburetor problem. Frank
