Cultivator lift arms
Jonathan Shivel
08-28-2006 12:11:14
I have a JD 2510 and I am wanting to get the lift arms under the seat working. I am told that they work off of a cable and spindle/
spool system. Thought I could fabricate a three point system if I get them fixed. Any ideas? Anyone done one of these recently?
Mike M
08-28-2006 12:23:06
 Re: Cultivator lift arms in reply to Jonathan Shively, 08-28-2006 12:11:14
It would be very unusual for a 2510 NOT to have a three point allready on it ????? The rockshaft is controlled by a lever up on the LH side of the dash,a cable runs from here down under the platform and over to the RH rear side of the rockshaft housing. If you take off the sheetmetal cover under your seat you should see the other end of it. The cables are available new from JD.
JWS
08-28-2006 19:49:31
 Re: Cultivator lift arms in reply to Mike M, 08-28-2006 12:23:06
That's what I was looking for. Cables. I was told the cable was broken. It really isn't a three point hitch. Replacing this cable a tough job? Thanks for the reply.
Mike M
08-29-2006 07:26:00
 Re: Cultivator lift arms in reply to JWS, 08-28-2006 19:49:31
It should not be too bad ? I think you need to remove the cowl piece from around the dash a few bolts and it lifts off. You may have an opening at the light/key switch area you can remove a bolt from and open it up.Remove the platform and the side cover from around the seat base. This is all easy if the bolts don't twist off. LOL
