2755 hydrualics
BC in NY
08-28-2006 11:35:17
Could someone tell me why the 3 point hitch arms and front end loader on this 2755 would jump and chatter when lifting? It is full of oil when sitting but after running the loader up and down you have to wait a considerable amount of time (5 to 10 min) for the oil to register on the stick again. I was told that the filter was changed as well as one hose. I don't want to buy this if it is something serious. Can someone answer this?
Thanx, Bill
cannonball
08-29-2006 04:43:21
 Re: 2755 hydrualics in reply to BC in NY, 08-28-2006 11:35:17
did they clean suction screen when they changed filter..screen could be stopped up..if so you might have larger problems... brakes, does it have hi-lo... water in fluid causes brake and hi-low problems. stops up suction screen..need a 3/4 allen wrench to fit a 2755 i think.. have nice day MAY GOD BLESS USA
PJBROWN
08-28-2006 16:07:41
There is 2 pumps in the 2755...one or both might be worn.. they could be picking up air. how many hours on it?
BC in NY
08-29-2006 06:08:25
 Re: 2755 hydrualics in reply to PJBROWN, 08-28-2006 16:07:41
The tractor has about 5,000 hours on it. It is a bit rough looking (worked hard put away wet).The loader will pick the front of the tractor up off the ground with ease. It is very jerky and jumpy with the valve pulled all the way open, if you only pull it back half way or so it is nice and smooth. If you rev the engine up it helps to smooth it out also. Don't know if there is anything in the screen or not, oil looks very clean and not milky.
BradS
08-28-2006 14:54:22
Bill Email me
