730D spec's?
Tx Jim
08-28-2006 03:46:51
Could a 730D rowcrop be ordered from factory with 7.50X18 frt. tires? Thanks,Jim
Duane Larson
08-28-2006 12:43:17
 Re: 730D spec's? in reply to Tx Jim, 08-28-2006 03:46:51
Jim,
The Rev. 2, March 2 1959 Deere Price List shows the 730D as coming with standard equipment dual front wheels with 6.00-16 6 ply fronts. Optional front wheel equipment includes 1) an adjustable tread front axle with 48-80 inch tread adjustment, 2) an adjustable tread front axle with 48-80 inch tread adjustment AND with 7.50-15 inch 6 ply tires, and 3) Fixed tread 38 inch front axle. Neither 1 nor 3 give any additional tire info, and that normally means no change from the standard equipment 6.00-16 fronts.
That doesn't mean there weren't some changed at dealers or where ever, but you would likely need to change the front hubs also so the tire wouldn't rub - probably the R1R hub would work.
Duane Larson
08-28-2006 06:10:56
Tx Jim,
You could order a tricycle 730D with heavy Roll-O-Matic with 7.50-15, or a standard with 7.50-18. A standard tricycle came with 6.00-16.
Tx Jim
08-28-2006 10:18:14
 Re: 730D spec's? in reply to Duane Larson, 08-28-2006 06:10:56
Duane,this is a JD square wide frt axle rowcrop tractor. Thanks,Jim
