1937 John Deere A
MT
08-27-2006 18:06:02
Hey guys- having water flying out of right side pet cock valve.Pulled the tractor and all kinds of water come flying out of exhaust pipe. {Exhaust pipe was covered}Was outside in heavy rain storm.Took head off and gasket looks good,block looks good.Any advice?THANKS
John T
08-27-2006 20:01:24
 Re: 1937 John Deere A in reply to MT, 08-27-2006 18:06:02
MT, Even with covered exhaust pipes heavy blowing rain water has a habit of sneaking in other places, but it sounds like you may have MORE then rain goin on there??? I wonder if the air cleaner lower bowl is full of water and it got sucked in, you may wanna pull it n see what you find??? I'm unsure which engines have the pushrod tubes and which dont, but if you take the valve cover off and have the tractor parked downhill and full of water if water comes tricking down the pushrod tubes into the valve area leaking pushrod tubes may have contributed to the water, but that water would have flowed down into the crankcase Ima thinkin.
John T
