620 gas shutoff?
shamic
08-27-2006 16:00:56
I would like to shut the gas off on my 620 John Deere when not in use. Above the glass sediment bulb is a round turn device that one can hold down on to let gas flow to the carb. If this screw is turned all the way one direction--is it a shut off? I know it operates with oil pressure as a shut off. Any help in this area would be appreciated. The needle and float in the carb seems ok,
Dale in IN
08-29-2006 07:46:54
 Re: 620 gas shutoff? in reply to shamic, 08-27-2006 16:00:56
Go to your NAPA Store and get a I/8'npt female/1/8'npt male brass shut off valve. I just put one off these on a 530 about 3 weeks ago. You remove your gas line and fitting from the auto shut off and the shut off valve will screw right in. Then you put your line and fitting into the shut off valve. You may have to set the shut off a just a little angle to make sure it will close all the way. Also you may have to put a little more bend in the gas line. This shut off valve will set well up under the hood and is fairly well concealed. The Part no is 6820 and it list for $7.22. You might get it for a little less depending on how your NAPA dealer treats you.
I Bleed Green
08-27-2006 18:47:30
It's a automatic shut off Right? You don't have to do anything to shut it off a automatic fuel shut off. When you shut the engine off the oil pressure goes down, and the gas is shut off. Now if you turn that nut down, the automatic with not open when the engine is running. I don't think their is any need for you to do this, unless you don't want someone (kids) to open the shut off when the engine is not running.
John T
08-27-2006 17:12:49
Shamic, NOPE, if you tighten that knurkled nut down it just tightens it up against the top which may or may not help keep dust out, but all it does is prevent you from depressing the lil screw/plunger to manually over ride the shut off to let gas flow even if theres no oil pressure. I used to think the same thing years ago but either the Frankster or the good Clooney man sent me a picture showing otherwise.
John T
