JD 5400
Spike in WI
08-26-2006 19:05:49
I just invested in my first John Deere tractor. It is a 5400 FWA w/loader. Can you JD experts fill me in on good and bad points to watch out for on this tractor.
Thanks
Spike
Brad the jd tech
08-27-2006 06:59:58
 Re: JD 5400 in reply to Spike in WI, 08-26-2006 19:05:49
The oil tubes on the engine ususally leak and you have to replace the o-rings. Keep checking clutch adjustments. The pto and fourwheeldrive levers sometimes break of if used very hard because they weren't welded very good from the factory.
buickanddeere
08-27-2006 06:06:11
Why purchase a tractor then ask if it's ok and if the price was right? The 5000 Ten models were upgraded 1/2 way through production to eliminate some weak points. They are more of a lightweight utility tractor than a HD loader or a high draft load hauling machine. As for myself I would look at a decent Mannheim Deere 50 or 55 series. Or a 6000 Ten or later Deere.
Spike in WI
08-27-2006 18:18:07
 Re: JD 5400 in reply to buickanddeere, 08-27-2006 06:06:11
Thanks for the reply.
I didn't buy it for heavy work. I bought it for mainly planting corn, oats and light work around the farm. The loader just came with the unit otherwise I wouldn't have it.
Spike
leon
08-27-2006 03:53:42
Usually these are pretty tough, reliable little tractors. Very maneuberable and handy. Lots of power for the weight especially in the 5400. Some of the early 52/53/5400 had problems with wear of the shifter linkage parts and they got hard to shift. Also there was some park pawl problems. The engines are a littly noisy with typical three-cylinder engine vibration. With the front end loader, be sure you keep plenty of weight on the rear end. Rear wheel weights and fluid in the rear tires likely won't be enough weight. You'll need to hang lots of weight on the three point hitch too. See your operator's manual.
