410 Backhoe defferential
Bewildered
08-26-2006 18:16:37
Thanks to all who gave advice on this tractor. I pulled the top off the housing and sure enough, it had broken the spider gear pin, bent the oiler assembly and the oiler pan. I have new parts coming, but how do I go about putting them in? Can it be done without disassembling the whole rear end? The gears look fine, is it possible to just loosen the bolts that hold the housing together enoough to slide them in and then tighten it all back up?
Thanks
Roy Suomi
08-26-2006 20:34:57
 Re: 410 Backhoe defferential in reply to Bewildered, 08-26-2006 18:16:37
When I do diff work on a 310/410 , axle housings come off , then ring-gear bearing quills [ watch the shims for correct preload , don't mix them from side to side ]Pull the ring gear housing out and split it apart to get a look at the spiders..
