1949 JD A Powertrol Lever
Scott Griffith
08-26-2006 17:27:51
Friend of mine has a 1949 JD A with a powertrol that is used to raise and lower a 3point hitch. When I push the lever full forward or backward and the hitch goes to the end of its travel either up or down, the lever does not return to center like it is supposed to. Does anyone know what I should look into to correct this problem?
Thank you,
Scott
Johnnydidd
08-27-2006 08:25:06
 Re: 1949 JD A Powertrol Lever in reply to Scott Griffith, 08-26-2006 17:27:51
Frank is probably right on low oil level, if that isn"t the problem there are pressure adjustments on the back of the Pwer-Trol. Email [email protected] and I will send you the adjustments info. John
F-I-T
08-26-2006 18:23:22
Just a quick one, as I am heading out, but typically if the unit is low on oil, it will not center. We used to throw the lever forward to lift the disk or plow, start adding oil, and as soon as it flipped to center, added a half-quart more and went to the field.
I bet it's low on oil.
Frank
