1010 gear grinding
Kevin Woodruff
08-26-2006 13:42:39
My 1010 will grind the gears when you try to put it in gear. I have tried to adjust the clutch, with out a book. No one around hear has one. Ordered one but still waighting. But no improvment. Once you get it in gear it is fine so long as you do not stay in nuturel to long between gear selections. Any ideas? Can any one email me the corect procedure for adjusting it? I cant beleve the clutch is bad as I just plowed with it with no slipping at all. Thanks for any ideas. Kevin
Kevin Woodruff
08-26-2006 17:21:37
 Re: 1010 gear grinding in reply to Kevin Woodruff, 08-26-2006 13:42:39
Thanks George,
I got it set right thanks to you. But I still have the problem. The PTO keeps spinning when you push in the clutch to. You can grab it and stop it easy enuf. But it will grind the gears when you put it in gear. I just cant seem to figure this one out. Could the pilot berring be bad and adding just enuf friction to make it spinn at slow speed? I realy to not want to split the tractor if I do not haf to. Thanks for any help!
buickanddeere
08-26-2006 20:29:12
 Re: 1010 gear grinding in reply to Kevin Woodruff, 08-26-2006 17:21:37
You are grabbing a spinning pto shaft??? When was the last time you greased the clutch?
Osage
08-27-2006 05:32:33
 Re: 1010 gear grinding in reply to buickanddeere, 08-26-2006 20:29:12
Buick&Deere:
I don't have a good book either(I got an I-T), where do you grease the clutch on a 1010RU?
Yes, my PTO turns even though disengaged, which to me is just a good reminder to "stay clear".
Thanks,
Osage
GeorgeH
08-27-2006 09:41:57
 Re: 1010 gear grinding in reply to Osage, 08-27-2006 05:32:33
third party image
From my operators manual..... .....
Kevin Woodruff
08-27-2006 04:36:42
I used a 2X4 to wedge against it. It takes very little presure to stop it. I just bought it last weak. I greased the berring right away. But I think it may be my problem, as when my wife presses the clutch in it looks like the hole berring is spinning. Seems like it should only be the forward half of the berring. I am afraid I am going to half to take it to my JD dealer. As I do not have time to split the tractor to do the clutch. I am sure it will get expensive quick! So mutch for my good deal! LOL
GeorgeH
08-26-2006 14:37:15
Check your E-mail.
GeorgeH
08-27-2006 04:58:30
 Re: 1010 gear grinding in reply to GeorgeH, 08-26-2006 14:37:15
Kevin, just out of curiosity (probably no bearing on the problem), which version of 1010 do you have (RS, U, RC etc)?
