Why does the 4020 need 2 batteries?
Ben Gubbels
08-26-2006 11:40:54
Why does the 4020 need 2 batteries? I can't understand why the 4020 needs 2 batteries stupid patenting i guess. All the Fords i got have 1 battery it's easier and charging 2 batteries is pretty awkward i don't know well guys answer my question.
Glen in TX
08-27-2006 10:40:30
 Re: Why does the 4020 need 2 batteries? in reply to Ben Gubbels, 08-26-2006 11:40:54
You must only have tiny fords? Aftermarket guys been making some nice side boxes to put regular size 12V batteries in 4020 and other new generation tractors for couple years now. Just bulges out a tad more on outside and don't have to use long narrow expensive batteries.
Henry M
08-27-2006 06:33:58
Just had some batery voltage brain gas. Then I realized that it was a 4240 that I worked on the electrical system the other day. It had two 6 volt batteries on it - one on each side - hooked in series. I think we finally found the bad connection and a toasted circuit breaker.
Richard Noggin
08-27-2006 05:15:57
Neighbor had 9600 FORD with factory cab 2 batteries under floor of cab, NOW THAT WAS REAL HANDY. How many batteries does a Powerstroke, 6.5G.M. diesel have? If batteries are your only problem you need to stick with C/IH/NH/Ford? giant grasshopper looking Blue TG series machines. (did not call them TRACTORS.)
buickanddeere
08-26-2006 20:31:04
 troll alert ....Re: Why does the 4020 need 2 batte in reply to Ben Gubbels, 08-26-2006 11:40:54
Go away little troll. You look, sound and smell like the Ford Selectomatic dimwitt.
billyiron
08-26-2006 18:40:25
thats cause runt little ford motors spin easy like your mouth!!!!! !!!!! !!billy
Pat P
08-26-2006 17:45:10
My "65 4020 was converted to 12V before I bought it. A single home-made battery tray was fastened to the frame next to the starter motor. Two 12V batteries connected in parallel for the extra current. The alternator was changed to 12V and I have to assume the starter was changed over too. Hasn"t given me any grief in the six years I"ve had it. I have to make sure the batteries are fully charged though.
Steve Crum
08-26-2006 17:08:54
I can't figure all the fuss over the 24 volts systems. We had 3010s and 4010s for nearly 40 years and once I remember a problem with 1 starter motor on the 3010 which got new brushes. other than that it was new batteries about every 5 years, nothing more and don't get me wrong, these machines were used hard but maintained well. The inconvienence of the battery location was no excuse for not checking the water levels and that the terminals were clean. The biggest thing was that the old mechanical hour meters pretty much conked out at the 12,000 hour point. So you could only guesstimate how many hours these had on them.
My 79' 310A backhoe came from the factory with dual 6 volt batteries hooked in series. These were never a problem for 9 years. Replacements would have been $242 in 1988 bucks, so I put in one big bad 12 volt for $139. and did it again in 1999. Maintenance is the key word.
Ha Ha Ha!
08-26-2006 14:26:30
 Still trying to stir up a stink Ben? in reply to Ben Gubbels, 08-26-2006 11:40:54
This guy needs tossed out on his ear.
Ray
08-26-2006 11:57:16
I always thought that was the worse thing about a 4020,2 of those odd shaped expensive batteries,
always something wrong with one side or the other,hard to change,one weak cell and it won't start.
John T
08-26-2006 11:53:54
Ben, The Diesels are a 2 wire isolated from frame ground 24 volt system regarding the Starting and Charging Circuits ONLY and use those two twelve volt (one on each side) batteries in series. The Starter is 24 volts and the genny works at 24 volts charging both the batteries in series. Where they are joined in the center they are bonded to frame ground which is how they derive two 12 volt (one + ground other - ground) with respect to frame ground A and B circuits to operate 12 volt lights etc.
The 24 volts is required to better operate the high HP and torque starters (at reasonable currents and voltage) necessary to crank a high compression diesel engine.
John T
Pete/ME
08-27-2006 03:34:47
 Re: Why does the 4020 need 2 batteries? in reply to John T, 08-26-2006 11:53:54
John T., when I got my 4020 a few years ago (4020D, PS, '66) the set up was: 2 12v. batts., each neg. connected to tractor frame separately, pos. terms hooked together and then to starter. Is this series? parallel? Never understood the difference, I flunked 8th science. Does this mean my starter & alt. are 12v.? I'm a carpenter, give me a pile of lumber and I'll build you a house, give me two batteries, and I'll electrocute myself. Thanks.
John T
08-27-2006 06:53:45
 Re: Why does the 4020 need 2 batteries? in reply to Pete/ME, 08-27-2006 03:34:47
Pete, what you describe is certainly paralell and the starter n genny and whole system would have been 12 volts, maybe it had been converted when you got it????? ???? The series connection is + of one battery to - of other leaving the series sum of 12 + 12 = 24 volts across the two unconnected + and - terminals on the opposite batteries. Same as in your flashlight where the + of one battery contacts the - of the other and you have 1.5 + 1.5 = 3 volts across both.
John T
Pete/ME
08-28-2006 03:00:47
 Re: Why does the 4020 need 2 batteries? in reply to John T, 08-27-2006 06:53:45
Thanks John T!
Glen in TX
08-27-2006 21:40:40
Pete and John, Later 4020s were all 12V system but I thought they still had the 2 long narrow 6V batteries on them or least the 70 model we had did. But 71 model 4320 had the 2 long narrow 12V batteries and so did 66 model 2510.
