Early 2240 Oil Leak
Pete/ME
08-26-2006 04:57:48
Oil (can't tell if it's motor or 303) leaking out of the hole in the bottom of bell housing-the one with the cotter pin to keep out dust--about a 2" dia. puddle after I run it for about an hour. Probably a seal, so it's time to split the tractor, (a winter job) unless there's an easier fix? (Maybe I over-greased the throw-out, but the clutch doesn't slip?)JD2240, #18399L
Brad the jd tech
08-26-2006 19:28:33
 Re: Early 2240 Oil Leak in reply to Pete/ME, 08-26-2006 04:57:48
Split it!
Pete/ME
08-27-2006 03:44:02
 Re: Early 2240 Oil Leak in reply to Brad the jd tech, 08-26-2006 19:28:33
Thanks Brad, crazy as it sounds I DO like messing around with the guts, never split one as new as this though, pretty straighforward? And do you think I could get by for ten hours or so by just adding oil to finish a job without doing any damage?
