B long hoods?
Scott's B haven
08-26-2006 04:20:33
What years did john deere make long hoods?
I just picked one up and I pulled the ser.# tag
off because It couldn't be read and I came up with ser#141413 which makes it 1942 before
they put the small radiator cap on them.So
is the right hood set up? Also it has a joy ride
seat like farmall was this a factory option?
Scott's B haven
08-26-2006 17:42:16
 Re: B long hoods? in reply to Scott's B haven, 08-26-2006 04:20:33
Thanks all
Will P. please email your tractors birthday I would like to know.why don't they have a kill switch?
j cook (iowa)
08-26-2006 08:21:17
The "long hood" is so named because of where the battery went, on the early styled B's. Early styled B's are those built 1939-46. Only the tractors with electric starters or those converted to electric start are "long hoods" however, as the hand start tractors don't need the battery box.
Will P
08-26-2006 06:30:13
Long hoods started in 1939 and went until the end of early styled. Nothing rare about them at all except for the 1939 and 1940 slant dash.
Your seat is aftermarket. I had one on my B.
You have the big cap radiator and a cast iron frame. The little presure cap came later.
She is a 1943 The list to the left is all messed up. Your tractor was built in 1942 as a 1943 model. Let me find the "birthday" papers for my B and that will be real close to your B. My B is 141524
Will
moseed
08-26-2006 10:03:26
 Re: B long hoods? in reply to Will P, 08-26-2006 06:30:13
Will P,
I am an IHC man that has recently found the family JD B (styled). Can you discribe what the slant dash is? I can't make out the serial #'s so as yet the year it was made remains a mystery.
Thanks
Will P
08-26-2006 19:11:47
 Re: B long hoods? in reply to moseed, 08-26-2006 10:03:26
It is just that. The dash, the part that holds the gauges is slanted. When Deere put the 5th and 6th speed in the trans. The shifter would hit the slanted dash. So, the dash was changed to flat just like the tractors without a battery.
Will P
