520 axle
Andy Conner
12-11-1999 05:24:21
We are replacing rear axle seals & brgs. on our 520. For the seals deere has 2 part #s , one for 88" tread < one for 97.25-104" tread. The axles stick out 15 " from the housing making a total of 85" width total axle width. We think this would make it fall into the 88" category. Are we right??? Thanks, Andy
Mike Aylward
12-11-1999 15:34:35
 Re: 520 axle in reply to Andy Conner, 12-11-1999 05:24:21
Andy, I think the long axles on a 520-530 are 3 1/8" (same size as the bigger Waterloo tractors) instead of the regular 2 7/8". I think if you check this it will tell you what you have. Hope this helps. Mike
Nate
12-11-1999 14:20:58
Your assumption sounds correct. As my 520 has the 88" tread width as yours does.
