630 Power Steering Leak into block
GP
08-25-2006 11:55:32
MY 630 John Deere is losing the power steering fluid into the crank case though the fan shaft. What seals/gaskets need to be replaced to correct this? I have a parts manual, I"m just not sure which seals to replace. Thanks!
donmyeil
08-25-2006 13:39:19
 Re: 630 Power Steering Leak into block in reply to GP, 08-25-2006 11:55:32
you need to remove the pump and replace the seals/shaft. probably needs gears ,fan drive discs etc. as well. good luck. Don
jturbo10
08-26-2006 16:10:05
 Re: 630 Power Steering Leak into block in reply to donmyeil, 08-25-2006 13:39:19
Just rebuilt my JD 50 power steering pedestal and power steering pump. The parts catalog will tell you to use two seals on the shaft however the single seals have been replaced by double seals so you will need four seals...two on each end. You should also replace the two keys on the gears as they are likely to be distorted. When you take the pump assembly apart you may have trouble getting the friction disks to move so you can get it apart. Mine were frozen to the shaft and I ended up cracking the top one. Had to use heat and solvent to get them off the shaft. I also replaced the friction disks since I had it apart. Lots of questions on what type of sealant to use for reassembly. I used Indian shellac but many use the Copper spray sealer used on heads etc. If I had to do it again I use the Copper Spray. Don"t forget to put some grease in the space between the seals so the outer seals have some lubricating agent. Highly recommend the 2 cyl power steering service manual which I believe is SM 2050 but don"t quote me. Saw one on Ebay for sale yesterday cheap. Good Luck
